<  BA Trackers  ~  How much Boost can I run? (TBI Only) Guide
TainterRacing
Posted: Thu Nov 12, 2009 12:50 am Reply with quote
Registered Modifier Joined: 09 Nov 2009 Posts: 50 Location: Petoskey MI
This is always asked. First off DON'T blame us if you blow your motor apart.
This is Dyno Tested Info or a True wide band info.
Say is you used..
Turbo and what psi
What exhaust system you have Include the manifold/header you run.
Stock Intercooler or aftermarket (Info on it Please)
Stock fuel reg, After Market (What Pressure if you know)
Stock Mass Air or 1g or other
Stock injectors (What year) After market (please the cc as well)
What Fuel.
Air Fuel
Other things will matter as well such as timing and Intercooler piping might have some bearing on what you can do and so will the motor VE and Compression, weather, and I am sure I have missed some others use this as a tool/ guide to what has worked for others with there car.
12a 19psi
Stock gutted cats
Stock IC
Stock Fuel Reg
Stock Mass air
Stock Injectors 89's
93 gas with oct Booster
A/F was Great at all rpms 11-12.5
14g 18psi
2.5in with muffler
Stock IC
Stock Fuel Reg
1G Mass air
93 gas
A/f was great to about 4500 12.5-11 over that was ok leaning out to 13
239HP@4800rpms 326TQ@3000rpms
View user's profile Send private message Send e-mail
funkyp
Posted: Thu Nov 12, 2009 1:02 am Reply with quote
Quickest 5sp A187 2.6 Joined: 09 Nov 2009 Posts: 968
What oct booster?
TainterRacing
Posted: Thu Nov 12, 2009 1:21 am Reply with quote
Turbo 108 Turbo Racing Fuel Concentrate not sure if they still make it in a 1qt tin can I think I have 3 of them in there. mixed to the max they say you can
http://www.amazon.com/TURBO-108-RACING-FORMULA-OZ/dp/B001BB1GQ4/ref=sr_1_5?ie=UTF8&s=automotive&qid=1257989917&sr=1-5
dan_brew
Posted: Thu Nov 12, 2009 11:46 pm Reply with quote
Registered Modifier Joined: 10 Nov 2009 Posts: 7 Location: DFW TX
14b Td05h 20psi
2.5" exhaust gutted cat no muffler
stock IC 89
Bosch fpr 40psi
3" maff with translator
Good set of 89 injectors
93 gas
Afr 10.5-11.2
238hp 331tq to the rear wheels on a mustang dyno
AnotherforumforPHINKO
Posted: Sun Nov 22, 2009 5:00 pm Reply with quote
Registered Modifier Joined: 13 Nov 2009 Posts: 9
My motor blew up. I am blaming all of you.
View user's profile Send private message Visit poster's website
Page 1 of 1
