<  BA Trackers  ~  MS - Stock Wiring Harness Pigtail
funkyp
Posted: Tue Nov 16, 2010 4:07 am Reply with quote
Quickest 5sp A187 2.6 Joined: 09 Nov 2009 Posts: 968
Im working on a pigtail for mike (starwolf) that will basically use his stock harness to run everything for MS. Hell just need to move a few wires. Since the MPS/ISC/Ignition Box will no longer be used, those wires will be repurposed for the new IAT/MAP/MSD.
Waiting for an ECU to show up and then work shall commence. Cool
Phil
View user's profile Send private message Send e-mail
StarWolf
Posted: Sun Jun 05, 2011 7:24 am Reply with quote
Registered Modifier Joined: 22 Jun 2010 Posts: 57 Location: Arkansas
Since there was never much of a following for this i figured i would post pictures of me putting it on my car.
BTW it worked amazing....and was SUPER easy to wire the 3-5 wires that i had to do...cake.
Connected right to the old wiring harness and right into the new FIP ECU.
1 or 2 ground wires...1 switched 12 volt and 2 i believe went right in to the wires from the ecu....super simple.
I would advise it to anyone to have one made my the funkness
_________________
Page 1 of 1
