<  BA Trackers  ~  SAFC Wiring Diagram with Stock ECU Pin out
funkyp
Posted: Sat Nov 21, 2009 6:30 pm Reply with quote
Quickest 5sp A187 2.6 Joined: 09 Nov 2009 Posts: 968
Cant remember who this is from.
View user's profile Send private message Send e-mail
dan_brew
Posted: Sun Nov 22, 2009 5:09 am Reply with quote
Registered Modifier Joined: 10 Nov 2009 Posts: 7 Location: DFW TX
87 TSI A connector:
W 1: IGN (coil)
WB 2: AFS
LR 3: Motor position SW
B 4: GND
GR 5: air Intake temp
YG 6: Coolant temp
YR 7: Idle SW
8: n/c
9: n/c
GR 10: +5 volt power
W 11: O2 sensor
YB 12: ISC (in)
YB 13: Ignitor advance
LY 14: MPS GROUND backup
GW 15: TPS
BW 16: Barometric sensor
17: n/c
18: n/c
LgB 19: Speed (coil)
RG 20: secondary air (catalyst)
BR 21: Diag. Output
WR 22: control relay (fuel pump)
YL 23: ISC + (out)
87 TSI B connector:
R 1: IGN +12 V
B 2: GND
B 3: GND
RW 4: EGR
BY 5: IGN START(cranking)
BW 6: AC switch
R 7: IGN +12 V
BY 8: GROUND
YG 9: Boost gage
YB 10: Injector 1 (primary)
BR 11: Ignitor signal FOR INJECTOR TIMING
YL 12: injector 2 (secondary)
B 13: +12 V CONSTANT
_________________
One bad TBI car, just ask Phinko.
Page 1 of 1
