<  STORE  ~  Customized Sterilization Pack
scx0127
Posted: Wed Aug 15, 2018 4:08 am Reply with quote
Registered Modifier Joined: 15 Aug 2018 Posts: 10
Quick Details
Material:EVOH & PA etc.Type:Stretch film, shrink film etc.Usage:Food&Medicine Film
Feature:Moisture ProofHardness:Soft, Soft for Plastic film forming customized zhongsuProcessing Type:Casting, Casting for Plastic film forming customized zhongsu
Transparency:Transparent, High TransparentPlace of Origin:Zhejiang, China (Mainland)Brand Name:ZS for PA/EVOH/PE 7 layers vacuum thermoforming plastic film
Model Number:EBF-83Thickness:35-380micron for Plastic film forming customized zhongsuWidth:200-2800mm for Plastic film forming customized zhongsu
Processing machine:W&H Plastic film forming customized zhongsuStandard:ISO,SGS,FDA,BRCSpecial Feature:Hight barrier packaging
Price:Competitive for Plastic film forming customized zhongsuTrustworthy supplier:Best service for Plastic film forming customized zhongsu
Packaging & Delivery
Packaging Details:Pallets,cartons,wrap,seaworthy export package for Plastic film forming customized zhongsu
Delivery Detail:On request for Plastic film forming customized zhongsu
Hi ! Welcome To Our Company
High quality products , Sincere service for you
ProductDescription :
Items Plastic film forming customized zhongsu. PA/EVOH/PE plastic film, multilayer film manufacturer. Co-
extrusion barrier film.
CertificatesISO,SGS,FDA,BRC
Thickness35-380micron
Width200-2800mm
ToleranceThickness Average Tolerance: +/-5%
Width Tolerance:0~+2mm
Elongation at break As per GB/T13022 (ASTM D 882)
Tensile Strength As per GB/T13022 (ASTM D 882)
StructurePA/PE
PA/EVOH/PA/PE
PE/PA/PE
PA/TIE/PO/TIE/PA/EVOH/PA/TIE/PO/PO/PE
Oxygen transmission rate As per GB/T19789(ASTM D 3985)
Vapor transmission rateAs per GB/T1073(ASTM F 1249)
Application Hight barrier packaging for thermoforming,suitable for meat,poultry,seafood and milk packaging
Bottom film for thermofoming on“FFS”automatic machine
Top film for thermofoming on“FFS”automatic machine
Vacuum packaging (meat,coffee bags)
Lidding film for trays with PP,PE,PS,(easy peel)
Fresh meat packaging
Our advantage :
1. Equipment:
There is the most advanced one Germany W&H eleven-layer cast film lines.
2. Competitive price:
We are the manufactory and not the trading company.
3. Accuracy:
We have strict quality control system.Good reputation in the market, ensure our products is exactly what you want.
4. Materials:
All cast films are made of high-quality raw materials.
5. Certificate:
Our products are certified by SGS, ISO,FDA etc.
6. After Service:
We can prepare all documents you need, and solve all problems related to the current order.
Application:
Lamination packaging bag
Retort pouches
Medical application,easy peel
For any inquiry about our cast film product offerings (stretch film, thermoforming film, etc.) for food packaging and medical applications - including further converted products;such as printed film and pouches
Hangzhou ZhongSu Packaging Materials Co.,LTD is professional innovation enterprise specializing in the integrates R&D,production,sales and series of multinlayer co extrusion case barrier film.We have more than ten years plastic film production experiences.
Our company production base has met full close air condition workshop accords with GMP100 thousand grade standard. lt has introduced the most advanced one Germany W&H 11layer cast film lines. There is a high efficient ream having rich experience, fine craftsmanship, the courage to innovate in our company. The production abilities of multi layered barrier films altogether can come to 6000 Ton every year.
We has met the requirement of quality system certification and complied with FDA food contact legislation. lt also passed inspection of China National Quality Supervision Testing Center of Plastic Product (NPQTC).Our company runs ERP management system and make the production procedure by network. The products show function for all kinds of packaging materials but not including chemical Benzene and waste impregant. lt can be recycled and also accord with the trend of green environment protected.
Hangzhou ZhongSu Packaging Materials Co.,LTD is committed to a variety of industry products for reliable packaging plastic film.We will try our best to use our innovation and profession, providing nowadays and future of functional plastic film and reliable packaging. Plastic film forming customized zhongsu. PA/EVOH/PE plastic film, multilayer film manufacturer. Co-extrusion barrier film.
Team spirit : Professional,earnest,sincere, patient.
R&D department concentrates on researching and developing reliable products with best quality.
The quality department test and control every processs of production to guarantee the best quality of products
Our Services
Supply you the high quality products and competitive price
Provide you with free samples and best service
Produce products at your request or your catalogue
Delivery goods with fastest speed
Welcome OEM&ODM and welcome to visit our factory
Packaging
Measure the size,use the core 3''or 6''
Install the VMPET protect film
Install the protect film label
Seal the two sides tightly
Use the tape to seal the foam pad
Pallets for all the roll films
For any inquiry about our cast film product offerings (stretch film, thermoforming film, etc.) for food packaging and medical applications - including further converted products;such as printed film and pouches. PA/EVOH/PE coextruded multilayer laminated film . Plastic film forming customized zhongsu. PA/EVOH/PE plastic film, multilayer film manufacturer. Co-extrusion barrier film.
Contact Person : Lansing
Tel: +86-571-86355968
Fax: +86-571-86355977
Cell-phone(Weichat & Whatsapp): +86-18969190305Customized Sterilization Pack
website:http://www.hzzs-packs.com/high-barrier-cast-stretch-film/medical-dressing-packaging-film/
View user's profile Send private message
Page 1 of 1
